12hp throttle shaft
Does anyone know where i can get a throttle shaft bushing for a k301 in my 123? I did a valve job on it and a new head gasket and rebuilt carb but it still surges a tiny bit at idle and ive done the best i can to adjust carburetor. The throttle shaft is awfully loose for my liking.
Your local hardware store should have them or can order them.
ok thank you ill have to check it out.
I got mine at cub cadet specialties, http://www.ccspecialties.org Also, if there's a lot of play you may also need a new throttle shaft as well.
| All times are GMT -4. The time now is 12:04 AM. |
