JD 317 with a rear mounted snowblower.
A friend of mine wanted a snowblower and a front blade on the same tractor so he built this himself. It is a very neet setup. It looks like it works pretty good. I know its a JD but still very cool.
https://www.youtube.com/watch?v=3MJQMjJs2oY |
JD or not, THAT is awesome. Now if only he would use his powers for good and do that to a Cub :biggrin2: :beerchug:
That is a sweet setup even if it is Green. :beerchug:
I don't care for the green paint either , but that is nice setup !!
He does have a 129 cub with hyd lift. The problem with a cub is making them lift independently. I think it would work better on a 140 H3 then he would not have to chain it up to use the hyd angle on the blade. He has a diverter valve for doing that but we are yet to plumb it in.
I like that it's mulit-funtional- you can do two jobs with one tractor, and that it has operable weight on the rear end. That being said, my neck already hurts. It needs giant truck mirrors mounted on the hood.
That is awesome, I want to do that. I may have missed something obvious, how did he power the blower? I don't see a belt from the front, rear pto? I see him flipping a lever, is it powered off the hydro pump output shaft? Is there another forum where he posted a build?
Thanks Bill |
| All times are GMT -4. The time now is 03:26 AM. |
