-   Kohler Engines (https://www.onlycubcadets.net/forum/forumdisplay.php?f=50)
-   -   K241A question (https://www.onlycubcadets.net/forum/showthread.php?t=36968)
hillscubs 01-29-2015 08:03 PM
K241A question
How much compression should there be on a K241A?
dvogtvpe 01-29-2015 08:17 PM
do you have spark advance or an ACR?
hillscubs 01-29-2015 08:19 PM
I am not sure. How do I tell? Also it is in a 109.
dvogtvpe 01-30-2015 06:37 PM
that should have an ACR. since it has an ACR you won't get an accurate reading unless disconnect it. Kohler recommends checking crankcase pressure. what do you have?
hillscubs 01-30-2015 08:38 PM
Im not sure how to check crankcase pressure. My compression is about 30lbs.
Redneck #1 01-30-2015 09:33 PM
I just wrestled with what I thought was a compression problem on a 12 hp. I also only had 30# compression. These guys on the forum correctly pointed out that the ACR would result in an inaccurate compression test. So your 30# may be OK.
Are you having problems with the engine or just inquiring about how much compression you should have?
dvogtvpe 01-30-2015 10:00 PM
download a Kohler manual. shows how to make your own water manometer and check it
