-   -   149 Lift Problem? (https://www.onlycubcadets.net/forum/showthread.php?t=37028)
Dadenstein 02-01-2015 10:00 PM
149 Lift Problem?
Hi guys, I have a 149 with a 42" plow, and it won't lift the plow more than about an inch. I can clearly see the piston has full movement range. Any ideas?
Jeff in Pa 02-01-2015 10:13 PM
Did you check for broken spirol pins in the rockshaft?
Is your lift rod the correct length?
Dadenstein 02-01-2015 10:16 PM
Jeff, the lift rod is the correct length, i don't know about the pins
Jeff in Pa 02-01-2015 10:40 PM
There may be welds instead of spirol pins ( I have narrow frames myself ) but you should get more lift.
Dadenstein 02-01-2015 10:46 PM
jeff, the pins and shaft are fine. any other ideas?
Dadenstein 02-01-2015 10:48 PM
https://mail.google.com/mail/u/0/?ui...&sz=w1334-h500 could this be a problem?
J-Mech 02-01-2015 10:51 PM
They can appear intact when in fact they are sheared.
kostendorf 02-01-2015 10:53 PM
A picture or video of the moving parts involved would be helpful.
Dadenstein 02-01-2015 10:56 PM
How would i do a video? same as a picture?
kostendorf 02-01-2015 11:07 PM
Take a video then put it on youtube and copy and paste the url here.
https://www.youtube.com/watch?v=s5Wj-zbS_V0
