-   -   Its alive!!! 1450 w/dual hydraulics (https://www.onlycubcadets.net/forum/showthread.php?t=37122)
budscub 02-07-2015 03:20 PM
My newly acquired dual hydraulics 1450. I bought this tractor just before Christmas. I ran across this on Craigslist and the dual hydraulics caught my eye. I hadn't had time to mess with it any. PO said it had a bad hydraulic leak and had been sitting for some time. Well with today's beautiful weather I couldn't resist to fool with it. Added hydro oil, put in a little go go juice, booster cables and...... nothing. Jumped directly to starter, ah ha we have rotation, but no bang bang. No problem, hot wire to coil, nope ain't gonna do it. I pulled plug :BangPC: no spark. Okay no problem pull point cover, hot feed to coil jump points with screw driver, it was the prettiest blue arc of life you have ever seen. Cleaned points re-install plug, presto change O, badda boom and badda Bam she hit faster the a politician on the campaign trail. This ole man is all grins. No smoke, no abnormal noise. I am thrilled. :biggrin2:
So as for the hydraulic leak I just knew it was the automatic check valves but no, the drive shaft is wobbling something awful, looks like a little seepage around the pump shaft. No problem, so now I will do cradle modification, new Iso's correct the drive shaft, replace the pump seals. Then I can play Ugh I mean work on it before giving it the "Restoration" treatment.
Oh I know the drill, Photos to follow.
Have a great day All..
BudsCub.
Sam Mac 02-07-2015 03:37 PM
presto change O badda boom and badda Bam is a good thing. :biggrin2:
budscub 02-07-2015 03:49 PM
Yes Sir, Sam it is especially when it is unknown. Still grinning, It is sitting out there idling as I tyoe this.
My garage is a total wreck right now and I should be running drywall mud, but hey I can do that when the sun sits. Just enjoying that K321 rumble at the moment. I have been enjoying this forum just reading and Listening to what everyone has to tell.
cadzag72 02-07-2015 05:34 PM
It's so satisfying bringing one back. Nice work!
finsruskw 02-07-2015 06:22 PM
You are gonna LOVE that front hydraulics if ya can find a hyd angle blade for it this or next winter!!
Just don't leave that ;ol girl sit out in the weather so's the dual handles get all rusted up and stuck. The last one I bought had been outside like forever and I cannot get 'em unstuck short of breaking out the gas wrench.
Enjoy!!
The 1450's are great rigs!
Shrewcub 02-07-2015 06:22 PM
Nice work, Gary!! On the 1450 and the post. That was fun to read!! :beerchug:
Now :WWP:
mjsoldcub 02-07-2015 06:31 PM
good for you!!! im excited to see this dual stick....
Sam Mac 02-07-2015 07:53 PM
Originally Posted by JLM78 (Post 310212)
glad some one got it not a dealer .That guy was Desperater for money that had that
"That guy was Desperater for money that had that" Please explain what you said? :bigthink:
budscub 02-07-2015 11:20 PM
Not really, he had a 125 also but I already have one. He was just reducing his inventory.
budscub 06-19-2015 09:36 PM
finally a pic
Well here is a photo of 2 of the boys, 1969 - 125, 1978 -1450 w/dual hydraulics. Finally got a little time and ambition to tinker. Found the main hydro leak to be the brake piston. Did cradle mod, moved top mounts to the bottom sway bar bushings on top. Made a new drive shaft to replace bent original. New bushing plate on crank, new flex disk, doubled the rear. Trunion repair new springs. All in all tractor is pretty sweet. Can t say as much for the deck. Low and behold another leak reared it's head, I believe to be axle tubes, but haven't played enough to wanna pull it back down.
