-   -   Bolt on snow plow (https://www.onlycubcadets.net/forum/showthread.php?t=37323)
billdunn64 02-21-2015 01:52 PM
Bolt on snow plow
Trying to install a bolt on plow on my 123 but the subframe is hitting the bottom of the axel.[ATTACH] .
Jeff in Pa 02-21-2015 01:58 PM
Post pictures of the ears where it bolts to the front of the frame.
billdunn64 02-21-2015 02:17 PM
Bolt on snow plow
2 Attachment(s)
I cannot get my bolt on snow plo we to mount on my 123. It is hitting the bottom of the front axel.Attachment 62157
Attachment 62158
billdunn64 02-21-2015 02:20 PM
Sorry for the double post I am doing this from my phone and it is the first time I have posted anything from my phone
Jeff in Pa 02-21-2015 02:56 PM
You need a pair of bolt on brackets from the front blade to frame.
billdunn64 02-21-2015 03:28 PM
what are those brackets that are on the frame made for
darkminion_17 02-21-2015 03:42 PM
Or the mule drive hanger without the pulleys and the undercarriage attached.
cub123 02-21-2015 03:55 PM
You need two of part #19, which are easy enough to make. Also you don't have to bolt it to the tractor, You can use a solid rod all the way through (#14) makes mounting/ removing a little quicker.http://images.partstree.com/?l=cub_c...20%5C0001&z=40
danfeste 02-21-2015 04:34 PM
2 Attachment(s)
If you have a mule drive bracket this is what I did on my 100, no extra brackets to bolt on and off to switch between blade and deck. This is what darkminion was talking about also.
