Replacing seals on trunnion shaft.
Hello everyone. I have a IH made Cub Cadet 782 that has a seal leaking on the trunnion shaft of the hydro transmission. The seal that is leaking is on the opposite side of the trunnion. I've never replaced one of these seals before and was wondering best way to go about getting seal out. I probably will have to pull the tranny to be able to do the work. Hoping all you have to do is remove the snap ring and washer and somehow pry and pull on the seal and get it out that way. Any ideas would sure be appreciated.:bigthink::beerchug:
put a small hole in the seal and screw a wood srew into it and you should be able to pull it out with some vise grips.
im with Jon on this one, removing the rear end is easy and doesn't take much time.
Ok..... probably longer than 30 minutes.... but like Tim said, it's easy and doesn't take that long.
Maybe I should add, roll the whole rear end out with hydro attached.
Don't know if you understood that, or at least I do it that way and it is a simple job, it really isn't that bad. I'm with the 30 min, ---hour @ most guys if you haven't done it before. I just pulled one on a 1650 today, wished it was as simple as yours, I have the hydro apart, as it is the seal on the trunion lever side. We will help if you have questions. |
| All times are GMT -4. The time now is 09:05 AM. |
