Timing
For the engine builders what is a good timing mark to run a k321 at or a ballpark and is 22 degrees to much?
What is your top end RPM? What fuel?
IIRC, 20° is the stock setting so, 22° is probably a good place to start. Timing depends on a lot of things. You have to play with it.... it's like tuning a carb. |
Not sure of the rpm its non governed but running 110 race fuel a fellow here at home told me to set it at 22.5 so I'm just getting some more opinions
Don or Austin would be better to answer, hopefully they will come along.
Since it's an open RPM motor, I would say that 22° may not be near enough timing. I would think more along the lines of 25/26°. |
Ok thanks but like you did you have to play with it I'm just looking a good starting point lol
timing depends on a few things, what type of ignition, plug location, number of plugs, stock or billet head, chamber design, compression ratio, carb size, fuel. I've run everything from 20 to 35 degrees ,
Stock head that's been shaved trigger ignition plug is over exhaust valve 110 racing fuel carb is a 26 kohler should be getting some work done to it this week the 26 came on it don't know why the guy took the 30 off but got it so gonna use it
| All times are GMT -4. The time now is 10:22 PM. |
