-   -   PTO bearing part number needed (https://www.onlycubcadets.net/forum/showthread.php?t=38154)
JWS782 04-08-2015 05:39 PM
I have a 782 with a KT17 series 2 engine. The PTO bearing started making noise, so in looking for a replacement, I noticed a rebuilt PTO on EBAY with a new bearing installed. So I figured I could do the same. I got the old bearing pressed out, but there are no numbers on it. These measurements are approx- ID-1 3/16, OD-2 7/16 and width - 5/8 in. I also was able to remove the sleeve inside the bearing, and it is in excellent shape. All I need is a bearing number. I know the replacement number for the clutch is 717-3044 and the original clutch part number is IH 144720-C91. Any help out there?
J-Mech 04-08-2015 05:49 PM
Hello and :Welcome2:
It's a 6206 bearing. You can get them at Napa. If you have the dimensions, a part store should have had no trouble getting you a bearing. Napa number 62062RSJ
JWS782 04-08-2015 06:43 PM
Thanks for the info!
I just called NAPA, and they will have the bearing there by tomorrow. I'll let you know how it turns out - thanks again for the quick response. It's the first time I used this forum, and it's great! John
bill682 04-09-2015 11:32 AM
I need to replace mine too, please update on your progress.
Does the bearing need to be pressed out/in or can it be pounded out/in with a socket and hammer?
Is there only one bearing on this model clutch?
I noticed a couple options from NAPA, is the more expensive bearing much better quality?
Thanks, Bill
http://www.napaonline.com/Catalog/Ca...RSJ_0309976200
http://www.napaonline.com/Catalog/Ca...RSJ_0329247594
J-Mech 04-09-2015 12:11 PM
From our tech section:
http://www.onlycubcadets.net/forum/s...ad.php?t=24413
JWS782 04-09-2015 02:59 PM
782 PTO bearing
I pounded out the old bearing with a piece of oak wood so I didn't mar the reducing sleeve. First I ground out the 3 stakes with a Dremel. There is only 1 bearing on the 782 clutch. NAPA charged me $31.49 - Bearing #62062RSJ. After the old bearing is out, I gently pounded out the reducing sleeve with a piece of wood. Put the new bearing in the freezer for an hour, and it will go in without much pounding. John
J-Mech 04-09-2015 03:19 PM
And I will note, it only is used when the PTO is in the OFF position. When it's ON the bearing is not in use.
bill682 04-09-2015 03:47 PM
Thank you John, you've been very helpful. Let us know how it turns out and if you think of anymore tips/advice for this procedure please tell us.
JWS782 04-10-2015 09:47 AM
Update on my PTO bearing - replacement was much easier than I expected. It sure saved me lots of money compared to the price of a new after-market PTO, or rebuilt one from EBAY. John
