60" Haban Deck
OK guys anyone have a front caster assembly for the 60" Haban I just busted mine off and it went under the deck and got destroyed before I even knew what happened. Is there any other items I can use for the front caster bracket?
Sam is 60" Haban expert...........:biggrin2:
Is it the 325 series 60" or 374 series 60"?
Timbo2 it is a 325 Series
Ok that's what I thought. I don't think that is a Haban deck, which is good because the Haban front caster would have probably ruined the deck and cost alot of money to replace.
While you are looking you should be able to run it with 3 wheels especially if you set the downstop to keep the wheels just off the ground. |
I thought the 60" 325 was a haban?
The 325 is sort of a cross between a Haban and a Cub. Problem is the front casters are NLA. You will need to try to find a good used caster from the sponsors. Do you have any pics of what you have left of yours?
Thanks guys I sent him a pm about 45 mins ago.
Try the sponsors at the top of the page.
Sam what blades do you reccomend I was thinking of Oregon Gator blades but they don't seem to cross from the OEM #
| All times are GMT -4. The time now is 06:09 AM. |
