-   -   Cub 123 PTO question (https://www.onlycubcadets.net/forum/showthread.php?t=39589)
coinman66 06-23-2015 05:51 PM
The little button seems to be pressed out the wrong way? I pushed it in, and pulled the PTO lever back in off position and it popped back out the wrong way again? Is this a common problem? How do I fix?
Thanks
darkminion_17 06-23-2015 06:05 PM
The button should be flush like this.
coinman66 06-23-2015 06:31 PM
So I guess mine is wrong? Do I need to tack weld it or something to keep from popping out?
darkminion_17 06-23-2015 07:10 PM
Is it a fiber button?
your is installed correctly it looks like it.
got a pic of it engaged?
Yosemite Sam 06-23-2015 07:22 PM
The buttons are about 3/4" in diameter, that little part in the picture is just the tit that goes in the hole to hold it in place.
budscub 06-23-2015 10:23 PM
Yours seem to be installed correctly, if it is sitting loose in the lever, you may need to peen around the hole alittle. What are you running for clearance when the clutch is engaged? Really should not be enough clearance that the button can get out of the lever. There is a spec just don't re-call it off the top of my head.
Maybe I mis-understood your opening comment, If you are thinking the small "nub" you are seeing should be flush, no it is fine, you want the large diameter to sit back against the lever.
