-   -   Cub Cadet 129 hydro problems! (https://www.onlycubcadets.net/forum/showthread.php?t=40398)
93cummins 08-14-2015 10:24 PM
I have a hydrostatic drive cub cadet 129 that's having issues. It runs awesome but won't drive. If it sits running for a few minutes I can drive it 10-20 feet then it just slows down to a stop like the hydro pump just looses pressure or something. Then let it sit another few minutes and you can drive another 10 feet. I flushed the fluid and changed the filter and no difference. I messed with what looks like 2 pressure relief valves on the pump and no difference and I replaced the o-rings on them and still nothing. What is wrong? I thought these things were bulletproof ? And when it does drive for that short distance it goes good I've driven it right up some steep ramps into my truck before
64fleetside 08-14-2015 10:50 PM
Proper fluid, proper filter?
Berwil 08-15-2015 12:44 AM
Originally Posted by 93cummins (Post 341595)
.....I messed with what looks like 2 pressure relief valves on the pump and no difference....
Explain. Are they auto relief valves (flush on top) or are they manual relief valves (pin sticking out the top)? If they are manual, do the pins move up and down freely when you push on them?
Bill
ford4150 08-15-2015 08:03 AM
http://ccmanuals.info/pdf/1x8-9%20&%...e%20Manual.pdf
Start on page 2-38
Also look at this:
http://www.onlycubcadets.net/forum/s...ead.php?t=4635
and this:
http://www.onlycubcadets.net/forum/showthread.php?t=3
James K 08-15-2015 02:09 PM
Check the roll pins in the drive shaft.
93cummins 08-17-2015 06:46 PM
They are manual relief valves and they move up and down nicely
zippy1 08-18-2015 12:24 AM
Please explain what you mean in more detail what is highlighted in red.
"Another few minuets", and "Messed with".
Yosemite Sam 08-18-2015 02:28 AM
While we're at it, please explain what this means: "I flushed the fluid"
