-   -   Words fail me on this mess (https://www.onlycubcadets.net/forum/showthread.php?t=40724)
Sam Mac 09-03-2015 05:24 PM
3 Attachment(s)
Why do I think drugs were part of the issue with this design.
http://limaohio.craigslist.org/grd/5170688965.html :beerchug:
"This is a mower/tractor I built a couple of months ago. It has a cub cadet 122 rear end and frame. And the extension frame is from a cub cadet 1225. The motor is a Wisconsin 4 cylinder engine that runs good. I had the mag rebuild and the starter rebuilt. Starts up good but may need a carb cleaning. Once it runs for a couple minutes it runs like a top. I had a drive shaft made for it and I did a lot of fabrication. Motor lowers and raises to tighten belt. Has a clutch mounted on the motor. Gas tank has a tiny hole at the top by the lid but it's not a big deal some just splashes out when you go over bumps. Both front axles steer together. Has 4 inch wheel spacers on the back, Ag tires and rear weights do not go with it. I have good turf tires I will put on the mower once sold. There is not another one like this anywhere"
Yep that is a pretty safe bet.
olds45512 09-03-2015 05:26 PM
$2600 for that pos? It's hard to see on my phone but is the drive belt running in a figure 8?
Mike McKown 09-03-2015 05:40 PM
On a positive note, I bet that tractor sounds good when it runs. Always liked the sound of those old V-4 Wisconsins running on a hay baler.
Sam Mac 09-03-2015 05:41 PM
2 Attachment(s)
Sure looks like it is a figure 8, guess that's how he dealt with the rotation problem. Here's your sign.
ol'George 09-03-2015 06:34 PM
Makes me wonder what he could do with a little guidance :biggrin2:
olds45512 09-03-2015 06:41 PM
He's got 4 steer wheels, I'd say there's plenty of guidance.:biggrin2:
Yosemite Sam 09-03-2015 07:13 PM
I too like the old Wisconsin engines, but that REALLY is the only thing I like about that old dog.
It reminds me a little bit of when Fred Flintstones car flips on its side at the drive-in when the girl puts the rack of ribs on it. Unless you never took it off the level ground, I don't know how you would ever keep it upright.
cadzag72 09-03-2015 09:33 PM
What ag tires? Those sure look like turfs to me!
john hall 09-03-2015 10:01 PM
We ALMOST put a 4 cylinder Deere power unit off a pull type combine onto a 100 Cadet roller. But then we came to our senses.:rolleyes: Actually acquired a combine to put the engine on and the rest of the parts to build the Cadet.
rocker582special 09-04-2015 08:27 AM
I saw that tractor at a show in richwood Ohio. It's a pulling tractor for sure but I would never own it. Especially not for $2600.
