-   -   NF front blade wont hit the ground (https://www.onlycubcadets.net/forum/showthread.php?t=40852)
Flingarrows 09-12-2015 02:34 PM
I put the front blade on the 105 this morning, and am wondering if I have the wrong lift rod. The blade sits 1/2" off the ground with the lift lever all of the way forward. What do you think:
http://img.photobucket.com/albums/v1...ps92rl1u7h.jpg
http://img.photobucket.com/albums/v1...psilgxrtos.jpg
olds45512 09-12-2015 02:52 PM
Id go buy some steel rod and make a new one, if you do you should put a 1" board under the front tires and set the plow on the ground to get the length.
darkminion_17 09-12-2015 03:16 PM
You have the wrong lift arm bracket on the blade.should looka lika dis one.the rod is 32 1/2 or so
johncub7172 09-12-2015 06:23 PM
Remove that lift stop. Those are for the mower deck usually. I removed mine on my 71, and the blade touched the ground fine!
:American Flag 1:
edit: That lift bracket on the blade is for another Cub Cadet dozer blade. Its unusual to only have one hole in the lift lever bracket as well.
darkminion_17 09-12-2015 07:15 PM
What he said.
johncub7172 09-12-2015 07:33 PM
My bet is on the lift stop, as I suggested. The slotted lift bracket on the blade frame is a sub frame float capability. I cant say for sure that slotted bracket is totally wrong.
Mork calling Olson, come in!
:American Flag 1:
Jeff in Pa 09-12-2015 08:12 PM
:American Flag 1:
Here's my front blade on my former 122
http://img.photobucket.com/albums/v7...h_DCP_5798.jpg
click for bigger pic
Works great and goes below level with the stop in place. :beerchug:
zippy1 09-12-2015 11:59 PM
What the master of Lew said...:beerchug:
Cub Cadet 123 09-13-2015 01:09 AM
Originally Posted by darkminion_17 (Post 345287)
What he said.
You quoted yourself?....I don't think I have ever seen that done.:biggrin2:. Bravo!.....Reminds me of Groucho's quote, "Before I speak I have something important to say."
Flingarrows 09-13-2015 05:51 AM
Thanks for all of the replies. Its hard to see in the pictures, but I turned the lift stop all of the way around, so it is not contacting. I actually took it off for a test as well.
Jeff, my lift handle is way far forward compared to yours, and is still lifted
Darkminion, thanks for that info. I'm new, and had another question. Why do they call you Lew? I have seen this all over the forums :bouncy:
Would anyone happen to know if these brackets are still available? If not I'll either post up on wanted, or weld up an adapter.
