Steering Column Question
Will a WF steering column fit a model NF model 73? My steering went out on my 73 and I was wondering if I could just do a swap. Thanks in advance for your information.
Cub Cadet 123 |
Pretty sure that the 73 uses a longer one than a wide frame has.
Cub Cadet 123 |
Yeah I believe the wide frames column are approximately 3 inches longer. NF Around 15" compared to WF around 18" IIRC
BASICALLY........all the GT steering columns are the same except for the length of the tube (or shaft).
| All times are GMT -4. The time now is 09:44 AM. |
