Looking for Mule Drive/Adapter info
I have a 782D that is currently running with a 44" Deck. As I understand it, a 50 inch deck can also be used with this tractor. Can the same mule drive/hanger/adapter that used with my 44 inch deck also used with the 50 inch deck?
Thanks |
I swap the 44's and 50's on my Quietline no problem.
Yes I do it all the time
Charles and Tim, so you use the same drive/attachment and it's as simple as unhitching one deck and connecting the other without touching the mule drive?
Correct, they use the exact same mule drive/under carriage.
Thank you Adrian.
| All times are GMT -4. The time now is 07:04 AM. |
