-   -   Cast end deck help (https://www.onlycubcadets.net/forum/showthread.php?t=41040)
cubcadet 09-28-2015 06:42 PM
Cast end deck help
Hey guys,
I am working on a friends 102 with what I believe is the 38in cast end deck, I measured from left blade end to right blade end as I was told to do, and I keep coming up with 38in, I ordered 2 new belts for the deck and the deck belt one I received is too short, so I was wondering if by chance I have a 42in deck and ordered 38in deck belts. Here's a pic of what I'm working with. Don't mind the 38in decal, as I put that one awile ago pretty sure it was 38in. Thanks,
Nick
R Bedell 09-28-2015 08:03 PM
You have the 1st generation of the 3 spindle 38" deck.
Mule Drive Belt = IH-473462-R4
Spindle Belt = IH-473468-R2
cubcadet 09-28-2015 08:55 PM
Thanks Roland, that should help.
cubcadet 09-29-2015 02:47 PM
Ok, I have the correct mule drive belt, but spindle belt is incorrect, I have part # 954-3002, wonder what that's for?
R Bedell 09-29-2015 03:39 PM
The 754-3002...>>>>> 954-3002 is a spindle belt for the newer 38/38A/38C decks found on the 1x8/9, Quietline, and 82 series tractors.
cubcadet 09-29-2015 04:51 PM
Thank you Roland.
cubcadet 09-30-2015 01:46 PM
What would the belt # 490489R2 be for? It was what this deck and tractor had as a mule drive belt, which I believe is incorrect because it kept coming off, it now has the correct mule drive belt which is # 473462R4.
R Bedell 09-30-2015 07:47 PM
Check the list out.....
