-   -   Spark plug (https://www.onlycubcadets.net/forum/showthread.php?t=41139)
drglinski 10-06-2015 05:40 PM
Spark plug
When should I replace a spark plug? Thinking about preventative maintenance on my 147 before winter. The current one is about 4 years old and still works fine. How to know/when to replace?
Thanks
rbarri2 10-06-2015 08:04 PM
When it's no longer working fine. If it's working, don't mess with it.
olds45512 10-06-2015 09:07 PM
mines been in the engine as long as ive owned it and it still starts and runs fine, im planning to do a new plug and wire in the next few weeks just to make sure its top notch for winter.
j4c11 10-06-2015 09:18 PM
I have developed a foolproof method of identifying bad spark plugs. You will need a multimeter for this. Measure resistance from the terminal stud to the threads where it screw into the block. If resistance is infinite, you got a bad spark plug. I have identified dozens of bad spark plugs this way .:Detective1:
Terry C 10-06-2015 09:24 PM
How many good ones do you find?:biggrin2:
j4c11 10-06-2015 09:25 PM
None, it works every time. They don't make them like they used to :biggrin2:
Terry C 10-06-2015 09:28 PM
:ROTF1: :beerchug:
