Clinton 700A Valves needed
Hey Guys,
I know this is a Cub Cadet forum but thought I would take my changes and ask a question. I have a Clinton 700A motor that needs new valves. Im hoping someone might have what I need. The original part number for the exhaust valve is 3031 which crosses to the IBM 291-1-990. The original part number for the intake valve is 3032 which crosses to the IBM 291-3-990. I have checked several sites and found nothing. Thanks everyone! Matt K. |
Try here, if you haven't already...
http://oldpathsequipment.com/product-category/clinton/ |
Clinton Valves
Thanks Ford4150,
I did look this site over. No luck! Matt K. |
Might be worth a phone call to them. Possible lead to another source or a valve that could be substituted from a different engine manufacturer.
Are your valves just needing ground or they MIA? beyond repair?:bigthink:
Clinton Valves
The exhaust is very pitted around the bottom seat and not much room is left for regrinding.
Close pictures of Valve and seat will help.:beerchug:
here ya go, ebay 300813915671.
or you can type in Clinton engine valve. |
When typing in the IBM valve numbers on Ebay search, leave out the abbreviation "IBM" but include the word "valve". The letters IBM seems to kill the hits because it is not used in the listing.
For example: 291-1-990 valve -or- 291-3-990 valve You'll find a couple of one type valves available but not the other (I forget which was the intake and the exhaust) However, you should also look in completed listing for unsold valves that has not been relisted. I believe there is one valve that has not been relisted that you may contact the seller with hopes of a sale........ and you'll find a couple valves that have been sold. |
| All times are GMT -4. The time now is 05:43 PM. |
