-   -   LED head lights (https://www.onlycubcadets.net/forum/showthread.php?t=41864)
1811woody 12-02-2015 01:22 PM
LED head lights
Replacement for the 4.5" sealed beam can be gotten from Larson LED it takes a replacement of a Par 36s
olds45512 12-02-2015 02:41 PM
Have a link?
MWShaw 12-02-2015 07:15 PM
Is this it?
https://www.larsenlights.com/par-36-...tt-flood-light
1811woody 12-02-2015 09:31 PM
Yes thats the one thanks MWshaw.
Steve N Mi 03-07-2017 08:04 AM
Some more possibilities can be found here;
https://www.superbrightleds.com/cat/...AR111,30,3370:
x.bhamcb 03-07-2017 10:40 AM
Has anyone done this successfully? I bought a set from superbright and haven't been able to get them to fire yetis my 149. I think the problem is in my switch/wiring, but everything seems to be as expected with a volt meter. I need to put a test light on it. (The bulbs light if wired directly to the battery)
Alvy 03-07-2017 11:11 AM
Remember those LED bulbs are polarity sensitive and if hooked up reverse they will not work
sir_lancealot 03-07-2017 11:16 AM
Yes, it's been done successfully. Check your polarity. Diodes only accept power in one direction.
http://www.onlycubcadets.net/forum/s...ad.php?t=47029
x.bhamcb 03-07-2017 12:35 PM
I am aware of the potential for polarity problems, in fact currently I have one bulb wired each way to keep hat base covered. (They may have resolved the polarity problem internally with these bulbs considering they are sold as AC/DC and superbright is usually good about telling you when a bulb is sensitive to polarity)
J-Mech 03-07-2017 02:00 PM
They can't solve a polarity issue internally..... it's an LED. Light Emitting Diode. The very nature of it is polarity specific. You either didn't get DC compatible lights, or they are bad, or you didn't wire them right.
