1872 rear end
When replacing bolts that hold the axel tube to the rear end do you use red locktite like it came from the factory?
I would use green or blue. but not red.
I use silicone and lock washers.
Thanks for the reply. J- Mech, I can't even pronounce the stuff you use!! But I will check at Napa for some to use on this project. I'm just hoping my son can get the 3 bolts out tonight, he has more experience at that than I do. " I really don't want to screw this up!" I think I have read somewhere while I have this apart that I can drill a hole so oil will drain better. Can someone refresh my memory on this. Thanks again guys!
http://www.onlycubcadets.net/forum/s...ad.php?t=24352 |
