-   -   Rear lift (https://www.onlycubcadets.net/forum/showthread.php?t=42439)
Jeff122 01-18-2016 04:10 PM
Rear lift
Does anyone have a picture or explanation of where the rear lift mounts on a 122? I just took a walk back to my shed to check it out and I am quite puzzled. Am I missing a bracket? Thanks again. Jeff
rocker582special 01-18-2016 04:58 PM
Any pics of what you have so far? We love pictures around here.
:TTWWP:
Jeff122 01-18-2016 05:16 PM
I will take a few pics and post them.
Jeff122 01-18-2016 05:33 PM
But for the record, i can use the rear lift for moldboard plow, and disc harrow on my 122?
Cub Cadet 123 01-18-2016 06:13 PM
(continued from page 2)....
and so you can hopefully find some assistance with this picture that is available in the Technical Section in the library of the forum.
http://www.onlycubcadets.net/forum/showthread.php?t=4
Both of these parts that are pictured are needed for the moldboard plow and disc harrow.
Alvy 01-18-2016 06:24 PM
Yes please post some pics. Hopefully you have the correct NF lift and all it's pieces
finsruskw 01-18-2016 06:27 PM
And you should probably keep an eye out for a spring assist set-up also.
Alvy 01-18-2016 07:10 PM
Oh I'm seeing that you have the hydraulic lift option as well so no spring assist needed
Jeff in Pa 01-18-2016 08:20 PM
http://img.photobucket.com/albums/v7...6.jpg~original
The extra washers next to the lift bar are not used. This was a failed attempt to use both the IH spring assist ( left side ) and the Brinly spring assist ( right side ) at the same time. There isn't enough room on a 125 ( hydro ) for the Brinly spring assist. You CAN use both on a 122 ( gear drive )
and the bracket underneath that the lift bar attaches to
Jeff122 01-19-2016 07:26 AM
Thanks everyone. Yes, CC123, I have all those parts. The lift assembly is for a NF. And the picture from Jeff tells me I have to remove a plate before I can install the lift parts. I will take a look again and take some pictures as well.
