-   -   Where do you get your battery cables? (https://www.onlycubcadets.net/forum/showthread.php?t=42973)
gdheck 02-28-2016 07:12 PM
I need new battery cables for my 982 and other than a dealer, no one around here has them. I think the dealer is a little steep for what you get. The local Carquest and Napa doesn't carry cables for small engine applications and they don't even have the correct wire and connectors to build the cables myself.
R Bedell 02-28-2016 07:17 PM
Around here, Farm Implement dealers will custom make them up.
Merk 02-28-2016 07:24 PM
I go to NAPA. Sometimes they have the cable I need. If they don't I will buy the wire, ends and shrink tubing that I need and make my own.
ccguy 02-28-2016 07:26 PM
Lowes has positive and negative 16" cables boxed together for $8. for our application (with the correct ends for a Lawn & Garden battery).
J-Mech 02-28-2016 07:31 PM
I make my own.
Yosemite Sam 02-28-2016 07:45 PM
I normally make my own, but here while back when I was at Rural King they had them there for less than $2.00 (each). I picked up a fist full of them.
EricR 02-28-2016 09:09 PM
:beerchug: Yep, make my own also, I work for a welding company and get my cable at a good price!!!
gdheck 02-28-2016 09:16 PM
Do you guys crimp, solder or both? What do you use for a crimper?
EricR 02-28-2016 09:33 PM
Crimp, we have a crimp tool at work and then solder afterwards..
J-Mech 02-28-2016 10:02 PM
I also crimp and solder. I use a crimping tool. What else would you use to crimp an end on wire? :Unknown:
