-   -   3 pt Kubota arms work on 1782? (https://www.onlycubcadets.net/forum/showthread.php?t=43037)
samckitt 03-03-2016 10:36 AM
Saw this for sale near me & wondering if anyone knows if it will work on a Cadet 1782. Looks like my tractor came with it but it's missing the arms. Wondering if this would work.
http://i242.photobucket.com/albums/f...tt/s-l5001.jpg
samckitt 03-03-2016 02:02 PM
Rear on mine looks like:
http://i242.photobucket.com/albums/f...207_094248.jpg
Hard to tell but the lower pins are there, I only need the arms, all of them, top & bottom. So I would just remove the lower arms from the shaft pictured above & use them along with the above pictured upper bar.
J-Mech 03-03-2016 02:06 PM
You are missing the rockshaft. On both your tractor, and in the Kubota parts. The bar in the Kubota parts is a lower shaft, not an upper. The arms might work, but your going to have to make the rockshaft, or buy one.
You know you can buy the correct arms from xtrememotorwork.com right?
samckitt 03-03-2016 02:39 PM
Rockshaft...... this?
http://i242.photobucket.com/albums/f...207_094302.jpg
This is less $ than the reman parts.
cub123 03-03-2016 03:48 PM
As Sam said, they could be made to work with enough fab work. Two issues I see to overcome are the arms don't have enough bend in them to clear the wheels and for the sway blocks to work, plus it's hard to say if they are the right length. 2nd, the links don't have any float like the stock ones.
samckitt 03-03-2016 04:32 PM
Anyone have dimensions of the Super's lower lift arms?
These are:
Lower Lift Arm
Center to center of Hole - 20.5"
Overall Length - 23"
Offset -4”
J-Mech 03-03-2016 04:46 PM
I could not see the rockshaft in the first pic you posted.
Carry on.
