-   -   Power steer column (https://www.onlycubcadets.net/forum/showthread.php?t=44020)
riesedesperado6170 05-07-2016 04:49 PM
Power steer column
does anybody know the part number for rebuild kit for powering steering. my leaking like a river the only thing I didn't rebuild:bash2:
ol'George 05-07-2016 06:42 PM
Sorry but my crystal ball comes up empty unless I put in a model number.
I would suggest you find the model number of what ever you are working on and try WWW.partstree.com or if it is a
cub cadet you could try cub cadet parts.
Then you could try cross referencing to find the best price, google works wonders, Luck!!
riesedesperado6170 05-07-2016 07:01 PM
sorry guys 1872
Oak 05-07-2016 07:14 PM
John Deere is AM107078 -- Pretty cheap here.
http://www.amazon.com/John-Deere-Ori.../dp/B00CSBVPGW
I'm gonna try this one next. Steiner 21-SK000011
http://www.messicks.com/search?q=21-SK000011
Parker #SK000097
riesedesperado6170 05-07-2016 08:03 PM
thank you sir :beerchug:
malchren 05-08-2016 04:23 PM
would that work for a 1862 power steering column as well? Also does anyone know who rebuilds the power steering cylinders in CT or some place I can send it to be rebuilt.
Thanks
Sam Mac 05-08-2016 05:00 PM
Probably the same parts for the control valve / pump. Member cubs-n-bxrs has rebuilt the steering cylinders you may want to PM him. I know he cuts them apart in a lathe then replaces the seals and welds them back together.
FrankF3 05-08-2016 09:35 PM
Where is it leaking from? When I got my 1772, it was dripping 2-3 drips per minute from the steering column. I found I had a bunch of loose fittings where the lines connect to the column. Once I snugged them all up - no more drips.
