-   Kohler Engines (https://www.onlycubcadets.net/forum/forumdisplay.php?f=50)
-   -   Crank and cam timing marks (https://www.onlycubcadets.net/forum/showthread.php?t=44081)
MattinmMichigan 05-10-2016 10:01 PM
I am having a hard time finding the timing marks . The crank I cannot find s punch mark on any tooth on the gear and the cam seems like the dot is right in the middle of the where if you turn the cam a hair either way it is gonna open valve right away
J-Mech 05-10-2016 10:06 PM
On ?????????????? What motor?????????
MattinmMichigan 05-10-2016 11:05 PM
K 321 in a 149
J-Mech 05-10-2016 11:40 PM
The mark on the crank is a "dash" near the gear. It's cast into the crank
The cam should have a "dot". Should be in a "valley" of the gear.
olds45512 05-10-2016 11:47 PM
[IMG]http://i1233.photobucket.com/albums/...psjmw1apv4.jpg[/IMG]
J-Mech 05-11-2016 12:28 AM
Originally Posted by olds45512 (Post 375491)
Yep. Just like that. :biggrin2:
dvogtvpe 05-11-2016 11:04 AM
you really don't need timing marks to put these together. put your cam in at split overlap then slide the crank in positioned at TDC.
MattinmMichigan 05-11-2016 11:11 AM
Thank you very much for the help J-Mech !
Jeff in Pa 05-11-2016 09:50 PM
K301 timing marks
http://img.photobucket.com/albums/v7...h_DCP_4978.jpg
click for larger view
or click this link
http://img.photobucket.com/albums/v7...d/DCP_4978.jpg
