-   -   1450 axle help (https://www.onlycubcadets.net/forum/showthread.php?t=4464)
lowlyfzlucky 05-16-2010 10:38 PM
1450 axle help
I have a Cub 1450. The front axle is moving to the right when steering the tractor. I just bought this and am working on restoring it. My question is if the front frame might be bent where the axle pin goes in. Mine has a slight bow in it, and I'm wondering if it should be perfectly straight across. Anyone know?
Thanks
Matt G. 05-16-2010 10:42 PM
The C-channel that the axle rides in often gets spread apart by the axle moving around. Remove the front axle, and then squeeze it back together with a 3/4" bolt and nut through the axle pivot in the frame. You might have to try it a few times until the axle fits nicely in the frame with no slop.
superduty5.9 05-16-2010 10:49 PM
This might help!http://www.onlycubcadets.net/forum/s...ead.php?t=1372
Methos 05-16-2010 11:16 PM
:Welcome2:
lowlyfzlucky 05-16-2010 11:30 PM
Thanks for the help guys. I'll try closing the gap in the frame channel.
