Sleeve Hitch CC 1641
Hi I hope you all can help me. I have a cub cadet 1641 and I am looking for a sleeve hitch. I know it was not made for one, but I wonder if anyone has converted a sleeve hitch manual or electric to work on a 1641. or does anyone have the measurements to have a 3 point hitch made for the 1641?
Thanks |
I have a frame from an 1864 which should be the same as a 1641. I'll look and see if a sleeve hitch will work on it. If it does, I think you can use one off of a 782. :bigthink:
4 Attachment(s)
This one is easy. Xtreme sells a lower hitch for the aluminum rears. Get the one with the ears that connect to the axle tubes. CC-29-010A
http://www.xtrememotorworks.com/Part...ve%20Hitch.htm Then pick up a cheap winch like Harbor Freight sells. |
Thank I look forward to see if it will work.
Thanks for the pics I had not though of doing it this way.
