-   -   Creeper (https://www.onlycubcadets.net/forum/showthread.php?t=46049)
ambrola 09-26-2016 09:10 AM
Creeper
I have always wanted a creeper for my Original, but have a question. It doesn't have the hole for the shifter and 2nd, is the wheelbase the same? Seems to me if you add something in the drive train, it will be longer? :bigthink:
Sam Mac 09-26-2016 09:35 AM
Download the service manual for the O
http://www.onlycubcadets.net/forum/s...ead.php?t=4645
ambrola 09-26-2016 10:07 AM
I have that manual Sam. I don't see the answers there? Am I missing something?
cubcadet 09-26-2016 10:08 AM
You need to cut/find a shorter driveshaft.
ambrola 09-26-2016 10:13 AM
I have one and a Danco creeper. I think what Sam is telling me is how to separate the tractor? I assume you just separate it and add the creeper. But then you have to cut a hole in the housing for the stick? I just can't wrap my mind around the fact that if I add something in the driveline, it should make it longer? And I should have said deteriorating mind.:bigeyes: Wait a minute, the shorter driveshaft difference takes the slack?
cubcadet 09-26-2016 10:15 AM
You will have to cut a hole since you have an earlier tractor, pull the clutch out, remove the 2 bottom bolts that hold to rear to the frame and bolt it on.
ambrola 09-26-2016 10:18 AM
Thanks, I think I have it figerred out. I might have to call the CC police to help on this one.:callyou:
Sam Mac 09-26-2016 10:19 AM
I thought the info was in the service manual but I was wrong. You will need to shorten the drive shaft to accommodate the length of the creeper, you'll need to cut the hole for the shift lever. Sorry but I don't have a creeper so I can't give you more info. Others that have them will probably chime in. Just wondering why you want a creeper? To me it just more stuff to go wrong.
cubcadet 09-26-2016 10:19 AM
Glad to help, sounds good!
ambrola 09-26-2016 10:21 AM
Because it's cool? The 2nd Original is getting optioned out. I have the parts, soooo:Duel:
