-   -   Another 169 redo (https://www.onlycubcadets.net/forum/showthread.php?t=46833)
Green stripe wide frame 12-04-2016 08:45 AM
Another 169 redo
I got this 169 in the summer of 2015 not running. Owner said he went to start it, it popped off, backed fired, and died. It would not restart. He said it was seized.
So I finally did some investigating, I got the motor out. I removed the pan and checked the balance gears all were good. Then removed the flywheel checked for a mouse nest, no issue found there either. Then I removed the head and found that the PO had left the the spark plug off and put side at that. Now the piston is seized. I sprayed some blaster around the piston, loosened it up and remove it.
Though did be able to save it but, after bonding it out and still being able to catch my finger nail on it, is not going to work. Looks like an over haul to the engine is required.
Pics to come
Terry C 12-04-2016 11:44 AM
Sounds like a good project. Keep us posted.:beerchug:
J-Mech 12-04-2016 01:17 PM
You should proofread......
Green stripe wide frame 12-04-2016 02:09 PM
Wow that's terrible, auto correct on my phone is to blame and me for not proof reading.
"The previous owner left the spark plug out and water had gotten in."
"Thought I would be able to save it. After honing it out found was not going to be able too. Had to much rust where the rings contacted the cylinder."
Thanks for pointing that out
Green stripe wide frame 12-04-2016 10:03 PM
2 Attachment(s)
The pictures would download of my phone, so here a couple
Green stripe wide frame 12-04-2016 10:08 PM
2 Attachment(s)
Couple internal pics
Green stripe wide frame 12-04-2016 10:13 PM
2 Attachment(s)
While I was tearing this engine down I found out it was a kohler short block with only 12 fine.
Oh well.
Green stripe wide frame 12-04-2016 10:16 PM
Called in the professionals to help move it to the psi washer
Green stripe wide frame 12-04-2016 10:23 PM
2 Attachment(s)
All cleaned up
Green stripe wide frame 12-04-2016 10:39 PM
Another issue I had with this thing was marking its territory all over my shop, so I drained the hytrans and remove the assembly from the tractor. Then removed the hydro from the diff found the for my seal all wet and a bolt missing from the hydro case.
I'm going to remove the trans assembly from a parts 149 and I think I'm going to use that hydro but the diff from the 169, then I'll transfer over hydralic lift too. :biggrin2::biggrin2:
