New member from Kansas.
8 Attachment(s)
Okay here's my story, I recently joined but have been looking at this site for a few years on and off. I finally got tired of not being able to see all the pictures and decided to join. I worked at an IH dealership back in the mid seventies assembling farm implements and of course Cub Cadets. I bought my first Cub Cadet while there and have been hooked for life. I think it was a used 70 or 100, I can't remember. I've owned several since then and currently have a pretty nice 782.
This past week I've been doing an engine swap do to a bad oil leak(front seal). I found a 1993 Huskee with a Kohler M20 so I thought I would upgrade from the KT-17 series 1. I did have to do a few mods but it wasn't bad at all. The biggest difference was the crankshaft on the M20 is an inch longer than on the 17. On the Huskee they had a one inch spacer behind the PTO whereas I put the spacer in front of the cub PTO, it worked out great. Another thing was the sheet metal up front had to be modified a little bit but worked out. Had to cut one for access to the oil filter. Had to reconfigure the choke cable and that's about it. Of course I had to do the relay thing which wasn't bad either. Thanks Roland Bedell for the drawings and wiring diagrams, I've used them a lot in the past. Also thanks everyone for all the great advice you give on here, even though I worked at IH, I'm no expert on them. If anyone needs that old KT-17 shoot me an offer. It's basically complete and has not been run without oil. |
Just saying Hi from the east of ya out of Missouri.
Del |
Welcome Flat!! KC, Mo checking in here. I grew up in Greensburg, KS, where is KS are you from?
Randy |
Hi Del, I just added more pictures. I didn't do it right the first time.
Hi Randy, I'm around the Topeka area. I have lots of cousins up around KC, MO.
Welcome to OCC.
Welcome. I have a daughter and family living in the north section of the Topeka area we get there usually in April and again in Sept.
welcome! I'm down in Augusta ks and I am also planning to put a m20 in one of my 782's however I haven't really looked into it yet. what kind of relay do I need and where did you get yours from?
It's just an automotive type relay, I got mine off of ebay but I suppose auto parts stores have them. I have a hard time finding stuff on this forum a second time, but somewhere on here there is a wiring diagram and explanation
of how to do it and what all you need. -Ray |
:Welcome2: Ray.
Good tractor you got right there.:beerchug: |
| All times are GMT -4. The time now is 11:59 PM. |
