Hybrid K-271 engine "stroker"
Might be the wrong place for this tread but anyone build/run one? If your unfamiliar with it it's a 10hp block and pistion with a 12 hp rod and crank "stroker" build
Never personally built one. But I'd imagine it'd be better/cheaper just to build the 12 k301....
I had some parts laying around going to pull it in the 10hp class. Going to have the cam ground. Just wondering where everyone set timing and what carb worked best
Most rules won't allow it.
I don't know if your familiar with engines at all or not, but you do know that the wrist pin on the 10 and 12 hp are different sizes right? |
I was just going off of the b miller site just wondering if any one has built one and if there is any thing noticeable diffrent about how it performs. I do belive kirk also had a write up on how to build one
Well, if your looking to Mr. Miller for advice on how to build, I think you'll be pretty disappointed. Most of his information is about 10 years old or older. I guess it's hard to keep up with the new stuff when your in prison.
I'm going to say this again.... so pay attention. I doubt your local rules will allow it, so better check. I really think you better stick to a standard crank. There are no gains in going to a 12hp stroke in a 10hp block. You can do more with it, without the extra stroke. |
Ask you questions here and you will get the info you need. If you want to pull in a 10hp stock class, you can't stroke it and be legal. If you can't win unless you cheat, give it up. Read and post the rules if you want help. Stock means different things to different groups. If on a even playing field, spending time getting youy tractor, tires and weights dialed in will get the trophy. Randy |
David Kirk has a few build ups on Killer Kohler ...... none were a stroker engine. As stated in an earlier post you need to check the rules.....most have a cubic inch limit. |
I just asked if anyone has built one! not the life story of B miller why would you state his personal stuff in a reply to my thread anyways? especially from a couple senior members from the site? And the rules are the "gray"area. I am sure the senior members commenting have never ran/built stuff within the "gray" area.
| All times are GMT -4. The time now is 04:48 PM. |
