-   -   QA42 snow thrower (https://www.onlycubcadets.net/forum/showthread.php?t=47809)
dagenham 03-13-2017 07:02 PM
QA42 snow thrower
Is there some trick to getting everything lined up when trying to bolt on the QA blower to my 127? It seems to me there is some trick I'm missing. It took me at least half an hour and one blood blister later I finally got both sides in place and the pins underneath all lined up at once. The darn thing is so heavy to move and wiggle into place.
J-Mech 03-13-2017 07:12 PM
Practice :biggrin2:
R Bedell 03-13-2017 07:14 PM
Do you have the Owners Manual...... Manual
PaulS 03-13-2017 07:35 PM
Be thankful that it is not a 450, 451 or 551. those are real brutes to get lined up and in place too.
dodge trucker 03-13-2017 07:43 PM
does anyone have a spare lift link for one of these QA 42's? I have one with everything "but" that. Will be going on (not sure which) my 1200 or my 129.
drglinski 03-13-2017 08:45 PM
You should do a #2 tiller. :biggrin2:
ol'George 03-13-2017 08:59 PM
Don't know about the 127's
but I find on dirt/uneven surfaces on the 782's, it is easier for me to mount the mule drive/gear box first,-- then slide the thrower up to it and put the lower shaft in, to marry the 2 together.
You do have to put the spline shaft into the yoke, before you slide it all the way together.
And it makes them easier to move around/store/lift as 2 units.
But it is just my way of skinning a cat.
Disclaimer:
No cats were harmed/injured in the process.:biggrin2:
Jeff in Pa 03-13-2017 09:00 PM
Lift rod?
I make an adjustable rod 28" - 32"
http://img.photobucket.com/albums/v7...h_DSC01770.jpg
rocker582special 03-13-2017 09:01 PM
I used to have a haben 42" snowblower. I ended up trading it for an old sears tractor. Not much room for fingers to help line everything up.
Jeff in Pa 03-13-2017 09:08 PM
Putting my QA42 on my 125 I found the best "trick" ( besides having two 125s :biggrin2: ) is to put a handtruck under the center of the blower housing and to line it up that way.
I do end up using the "universal adjective" quite a bit if I have to install it myself. An extra set of hands is a big help
