-   -   My 1450 Adventure (https://www.onlycubcadets.net/forum/showthread.php?t=47948)
johncub7172 03-25-2017 11:44 PM
My 1450 Adventure
Hey guys!
Had been thinking for a while now on what to do with my 1450. It's my favorite IH Cub Cadet ( honestly all four of mine are my favorite )! There happens to be a weird noise coming from the trans axle...... whether this noise is from the drive line and related components, or the hydro pump unit, or the cast iron trans axle portion of the assembly, my objective is to inspect all of this with a fine-tooth comb to find out this problem. My method of repair will be determined on what is found.
Tonight, I removed all the sheet steel on my 1450. I will start to document and make upgrades to it. I will be following the BRSM closely, as it will help me to properly understand, and translate parts, functions, and correct assembly steps. I have put some thought into this, so I'm hoping to have a good documentation. The last goal is to clean the tractor, and assemble. I will continue to carry the IH 38" three-blade mower deck on the tractor, but I'm not going to use it. There are a few small things needed repaired. I have purchased a fair sum of parts and components for the drive line back to the rear wheels.
This will be a slow thread. I will post a lot of information. My thread will not drop off and fade to black. I don't plan to paint any parts as of yet, but that could change. Despite this unusual noise, everything about it works and functions fantastic, which is a good way to start this project.
john hall 03-26-2017 08:06 AM
May I suggest posting a 'before picture" of the 1450. You've seen it all too many times---a beautifully fixed up machine, but nobody knows what you started with. I know you SAID no paint, but until it leaves the shop just as faded and rusty as it came in, although I imagine you'll give it a good bath while it is torn down, well, you know the rest. :BlahBlah: :biggrin2:
:TTWWP:
johncub7172 03-26-2017 09:29 AM
A Few Of My References
1. Only Cub Cadets.net
2. Blue Ribbon Service Manual # GSS-1464 w/ Revision 2. September, 1979
3. 50 Years Of Cub Cadet by Oscar H. Will lll
4. Farmall Cub And Cub Cadet by Kenneth Updike isbn# 0-7603-1079-3
5. Cadet Connection Magazine, and Special Information Catalog #4
6. Cub Cadet Lawn & Garden Tractors "The Quiet Ones"
7. Haueter's Lawn And Sport Center- authorized Cub Cadet dealership, Middlefield, Ohio ( 440-632-5997 )
8. Cub Cadet Specialties Vintage Cub Cadet Parts- Park Rapids, MN
9. Cubcadetcollectors.com, IHCubcadet.com, farmallcub.com
10. International Cub Cadet 1000, 1200, 1250, 1450, And 1650 Tractors Operator's Manual
11. International Rotary Mowers 38A, 44A, And 50A 3-spindle Setting Up Instructions Operator's Manual
12. Kohler K-Series Single Cylinder Engine Service Manual K91, K141, K181, K241, K301, K321, And K341
johncub7172 03-26-2017 09:49 AM
Some Official Part #'s Used On My 1450
1. Cub Cadet Service Kit # 759-3952 ( iso mounts ) code: CC-405
2. Cub Cadet flex joints # 722-3000
3. Cub Cadet hydro fan # IH-547749-R2 w/ Cub Cadet heavy duty snap ring # 916-3000
4. Cub Cadet hydro pump gasket # 921-3004
5. Cub Cadet front rim assembly # 934-3078A
6. MTD front wheel bearings # 941-3002 ( made in U.S.A )
7. Cub Cadet K321 engine oil pan gasket # 921-3001
8. Kohler K321 carb. kit # 25-757-02
9. Kohler K321 head gasket w/ fire ring # 47-041-15S
* The above list will continue to be updated as warranted
** Cub Cadet Fluids And Filters
a. Hydraulic oil filter: Cub Cadet # 923-3014
b. Hydraulic fluid: Cub Cadet Hydraulic/Transmission Fluid # 737-3062
c. engine oil: Cub Cadet Low Ash # 737-3029
d. Kohler K321 engine air filter:
johncub7172 03-26-2017 09:55 AM
:TTWWP:
We'll do John!
There is an impressive OCC thread on a Quiet Line with about 56K views,..... my adventure thread will not come close to that! Ha!
johncub7172 03-26-2017 10:19 AM
My 1450 Master Plan
* Remove all sheet steel: inspect and clean.
* Remove engine: notice any gaskets that may need replaced, complete cleaning and check the torque of the oil pan bolts.
* Check new ISO mounts and engine cradle for wear.
* Check cradle snubbers and reset the gap.
* Clean engine bay, frame, and front axle components.
* Clean and grease front wheels and spindles.
* Swap out starter for a better one that "catches" every turn of the key.
* Repair/mount wires to headlamps.
* Get new ISO lock nuts.
* Clean rear tires & rims-install new 1/4" off set rim spacers.
* Currently has a QL1250 i.d tag-swap out for a 1450 i.d tag since engine will be removed.
* Drill two 5/32" holes into the rear lift to install two press-in grease zerks.
*Transmission : Find out where noise is coming from.
* upgrade to dual disk drive line.
* Install new drive flange.
* Install all new gaskets and seals.
* Upgrade to automatic check valves.
* Remove axle carriers-inspect bearings.
* Swap out two IH stamped rear cover bolts for the correct WP monogram bolts.
* Might add an extra snap ring to the hydro fan to secure it better.
* Reline the rear caliper brake pads.
I'm sure I will find more to do :biggrin2:
johncub7172 03-26-2017 11:02 AM
A little Back Ground History About My 1450
I got my 1450 around April 20, 2014. It happened have a good six pad seat, with out many cracks, and still looked black as coal. The front headlamps worked great, and the rear tail lamps worked too! However, the headlamp switch was not the original switch. I happen to luck out to find an original headlamp switch specific to the Quiet Line model. The rear tail light lens were both cracked. I saved those when I stumbled upon a nice, original set that I replaced the cracked lens with.
The 1450's front engine power take off device worked just fine, as well as the Maintenance Minder, which registers up to six hundred hours of operation. I have a nice IH insignia amp meter as well that functions accordingly. The ignition switch was replaced with a new Cub Cadet switch before I received the tractor. I also found a neat IH stamped cut out ignition key! Everything my 1450 rolled out of the factory with, still works to this day! That's a well built machine to have stood this on-going, testament of time.
I found that all of the engine tin was badly destroyed. I gained used engine tin for the Kohler K321 AQS that was in nearly perfect function from other Quiet Line tractor parts. I even found a nice condition muffler, and a belly pan with no cracks or broken tabs. My 1450 came with a rear lift, but no sleeve hitch.
twoton 03-26-2017 11:28 AM
:popcorn:....
zippy1 03-26-2017 11:04 PM
Looks like you've got a good list going. NOW as John mentioned earlier, :TTWWP:
We enjoy going along on the adventure.:beerchug:
OldSkull 03-27-2017 09:41 AM
Got plenty of those with or without base, can sell you a pair for a fair price just PM me. :beerchug:
