-   -   Steering spindle question (https://www.onlycubcadets.net/forum/showthread.php?t=48433)
Shotgun Clay 05-01-2017 10:03 PM
Hi, I have heard about 1 (or 3/4 possibly) in spindles and wondered what cub they are on, would they fit a 149? If it works, does it increase the max capasity of weight much?
Thanks
olds45512 05-01-2017 10:52 PM
You will find the 1" spindles on the 82 series on up, i would assume they will take more weight since the bearing is also bigger but how much i'm really not sure. If you're interested in some shoot me a pm.
IHinIN 05-02-2017 04:59 AM
I have 1" spindles on my 129. They came off of a late production 1650. You'll also need the wheels to go with them.
R Bedell 05-02-2017 05:26 AM
The Steering Spindles (knuckle) used on Cub Cadets breakdown as this:
* 3/4" used from S/N: 501 to 632501 (Mid Quietline Production)
* 1" used from S/N: 632502 and greater
:IH Trusted Hand:
Shotgun Clay 05-02-2017 08:26 AM
Ok, I now understand this. Could I just get a different wheel bearings, or would I have to get a different rim?
R Bedell 05-02-2017 08:28 AM
The correct rim for the correct bearing.
ol'George 05-02-2017 08:44 AM
Clay,
if your using the unit for normal duties a 3/4" spindle will work fine.
They went to the 1" for improved bearing life and thrower duty.
A lot of those things are still working with factory bearings on 3/4 axles.
if it were mine I'd leave it alone unless the axles are worn or bearings wallowed out in the wheels.
Then look for the 1" setup.
Now if a feller was ah gonna hang a loader on the thing, a 1" setup would be needed.
:beerchug:
johncub7172 05-02-2017 11:36 AM
I can't agree more with the above! There is a Cub Cadet 1" front rim, and respected inner and outer rim bearing numbers listed in my 1450 adventure thread should you go this rout.
