Onan ?
:Morning: Onan BF-MS 2833D. Pulse fuel pump built into carb. Will not pull fuel. I have rebuilt the carb and pump with all new parts. My though is the pulse is too weak from the valve cover. Is their some where else that that I can pick up the pulse? Any ideas/suggestions will be greatly appreciated. Thank you for your time.
:American Flag 1: |
You sure it's not just having trouble priming? That's common after a rebuild.
No, pulse will be the same no matter where you pick it up from. If the pulse is that weak, then the motor is shot. I doubt weak pulse is the issue. Edit: I suppose there could be an issue with the vent valve. I'm not too familiar with the Onans. I've worked on them, but not much. Most all small engines have a reed valve. It could be a problem with it. I'd try pouring gas down the carb to get it to run a bit and see if it starting picking up fuel. |
| All times are GMT -4. The time now is 10:32 PM. |
