169 mower belt size
I have a recently acquired 169 that came with a 50C deck. Not sure if it was the original deck. It did not come with belts. Does anyone know what size belts are needed to get it operational?
Thanks |
If it is a 50C it will not work unless someone changed the center pulley on the mower. The C uses a 5/8" belt and the PTO on the tractor uses a 3/8" belt. You need to check the pulley size on the mower.
I'll have to go look.
I looked up which decks came with it and tractor data said 38 44 and 50? |
There were three (3) versions of the 50" deck. A) Model 50 for the 1x8/9 Series B) Model 50A for the Quietline Series C) Model 50C for the 82 Series. Thus it is important to know the differences so the correct parts can be used. |
Thank you for the info.
If I change the center spindle as mentioned, will it work? Seems to be in really nice condition |
Hot diggity dog!!!
It's already 1/2"!! Do you know what size belt I'll née to the pto? |
Pulley must have been changed by PO.
Do you know what belt I'll need? Thanks! |
What diameter pulley did they put on it?:bigthink:
