-   -   Idler Ratchet Dimension (https://www.onlycubcadets.net/forum/showthread.php?t=48919)
scarps68 06-05-2017 09:41 PM
Does anyone happen to have the dimensions of the 50" mower mule drive idler ratchet? 703-0138-0498
darkminion_17 06-05-2017 10:16 PM
Do you have one to go by? I have a few but I will not measure,heaven forbid it get it wrong and you will no longer like me.
Why not buy one on flea bay?
scarps68 06-07-2017 08:34 AM
When I bought the tractor it never had one. I've been breaking my stones each spring mounting the deck. I have metal stock laying around figured I'd just make my own.
R Bedell 06-07-2017 09:27 AM
2 Attachment(s)
I just lost one on my 50C. I made one from flat stock that I had lying around. I made mine 7" long but if I had to redo it, I would go 7.5 or 8.0 inches. I used a "T" configuration instead of the OEM "L" design. I placed a slight bend near the 3/8" hole to align with the idler pulley. See images
Berwil 06-07-2017 10:12 AM
My mule doesn't have the ratchet either. I stick a 9/16" wrench in the slot, engage the nut, and push on the wrench to slack the belt for install/removal.
Bill
Dart1917 06-07-2017 11:30 PM
Let's see if this works-
scarps68 06-10-2017 02:45 AM
Thank you all. Now to find the time to put one together:bigthink:
