QL dual stick front outlet pipes question
4 Attachment(s)
Guys,
I converted my 1650 to dual stick with all factory parts. Up front where the two lines go along the frame how are they held in place ? The spot welded clips do not quite line up at the rear. Could anyone provide a good picture for me please. Also the holes I need to drill for the two couplings, I measured the ones I had and they are 7/8 OD. They are Bruning D-201 Are these the correct couplings for the QL before I drill and file holes ? I will at some point get an angle plow setup. I need one more coupling if anyone has a good spare ( my other has been wallowed out where it previously went thru the frame ). I would just need the coupling and not the adaptor fitting. The goal is to get it up and running mechanically perfect and next chance I get will do a bare metal repaint. After I mount the front pipes Im ready to start installing the motor and finish assembling the rest. Thanks Carroll |
Hi, the lines are not clamped. Since they are ridged, it's not necessary.
The outlets you have should go on the shelf or be sold. They are crazy expensive and the male ends that plug into them are about 25 bucks each. Go buy 1/4" female couplers from tsc, or XMW. The male ends for those are about 4.00 each from surplus center |
The correct Front Couplings were IH-166122-C92 which are Parker SM-251-4FP.
:IH Trusted Hand: |
Thanks, ordered two Parker couplings on line. Tractor supply did not have the correct couplings that can be held in with the snap ring, the parker is .
| All times are GMT -4. The time now is 06:09 PM. |
