-   -   Peco bagger propeller (https://www.onlycubcadets.net/forum/showthread.php?t=49350)
Tchristmas 07-11-2017 07:16 PM
Not sure if I'm posting in the correct forum...but... I had a nice peco bagger givin to me and I recently , somehow mounted it to my cub lt1050. My question is is pertaining to mounting the new propeller. It's the correct part number. A0124. It's a cast aluminum double blade prop. With a 3/4 shaft on a 4hp Briggs. My question is this. Does it simply go around the shaft and tighten around the shaft with the 2 bolts or is there something that threads into the center of the shaft. Also the little wing on the left prop.. which way does that face. The old prop was in 20 pieces when I took it apart so I have no clue how it was on before. See link to picture. Thank you so much for ur help!
http://m.ebay.com/itm/282375894489?_mwBanner=1
Tchristmas 07-11-2017 09:26 PM
The prop can only go one way so I guess I answered one of my questions...
J-Mech 07-11-2017 11:20 PM
You got it in the correct section. :ThumbsUp:
Well..... you have the machine in front of you, and you didn't specify the model it is, so how can we help? I'm sure that the impeller clamps to the shaft, but as far as if there is supposed to be something in the center.... well, is the shaft threaded on the outside? How about internally? I can't see it from here... If it's threaded on one or the other, I would assume that it's supposed to have something on it. If it's not, then likely no. I would think that the clamp feature of the impeller would function as a safety feature to keep it from breaking the shaft. If something gets into the impeller, it can slip. But, I'm just making an educated guess....
Also the little wing on the left prop.. which way does that face. The old prop was in 20 pieces when I took it apart so I have no clue how it was on before. See link to picture. Thank you so much for your help!
The impeller can only go on one way..... how can the "wing" be on any other way than the only way it will fit into the housing? :bigthink:
