-   -   782D stopped hydro-ing... (https://www.onlycubcadets.net/forum/showthread.php?t=50601)
jbrewer 11-20-2017 06:24 PM
Long time no see, friends!
I was doing the last clean up of leaves (maybe) this year and was bringing my 782D back towards the garage. I was motoring forward and lifting the deck at the same time and hydro pressure just died.
There's no propulsion or any lift of the deck. Engine runs fine, and there's no leaks.
Where to look first?
John
Shrewcub 11-20-2017 06:54 PM
Check the spiral pins on the drive shaft.
finsruskw 11-20-2017 07:01 PM
I agree..
Better lay on some spares while you are at it, you are gonna need 'em
J-Mech 11-20-2017 08:28 PM
http://www.onlycubcadets.net/forum/s...ad.php?t=50335
:biggrin2::biggrin2::biggrin2::biggrin2:
DoubleO7 11-20-2017 11:39 PM
http://www.onlycubcadets.net/forum/s...ht=pins&page=2
Dowel pin on engine end.
Spirol pin on pump end.
Check pin holes for elongation in all parts the pins touch.
Eliminate elongations.
Jeff in PA makes a dowel pin that is slightly bigger to fit into shaft at engine end when pins are being slung out.
olds45512 11-20-2017 11:55 PM
The 782 doesn't run a dowel pin at the front of the shaft like the older Cub's.
Oak 11-21-2017 07:12 AM
John, you sheared the pin off at the hydro input shaft.
http://www.onlycubcadets.net/forum/s...hlight=sheared
jbrewer 11-21-2017 12:47 PM
Sounds right but wasn't right. All pins are working, input to hydro pump is spinning. I will double check this though.
I did discover that the DPO neglected to tell me that all the fins on the cooling fan were broken off.
Any next hints?
I can see that the linkage from F/R lever is working fine.
BTW, this stopped all of a sudden...there was no loss or degradation before the failure.
John
Sounds right! I'll have to go see how to tunnel cover removes and give a look see. Doesn't sound too bad.
I guess the load of pumping the PTO lift and the motor at the same time exceeded the (probably OEM) shear pin.
Back in a bit!
jbrewer 11-21-2017 01:42 PM
To no ones surprise it does indeed look like the spirol pin! I drove it out and it came in small pieces.
Thank God for Kroil and long roll pin punches!
finsruskw 11-21-2017 02:18 PM
Was it a spirol pin or a plain roll pin?
