-   -   1872 Cast Iron rear swap (https://www.onlycubcadets.net/forum/showthread.php?t=50605)
ClickClickBoom 11-20-2017 07:40 PM
Working on swapping a cast iron rear into my 1872. trying to get the new rear back under the tractor, and the front mounts that were for the aluminum rear look to be about 1/4 - 3/8 to narrow for the new rear to slip inbetween them. I measured the frame thinking it might have flexed inwards, but its the same top and bottom all the way across.
Are they not needed, or do I need to modify them a bit? Didn't see any mention in any of the other swap threads.
darkminion_17 11-20-2017 08:07 PM
The old cubbies did not have brackets, they just bolted to the frame directly.
ClickClickBoom 11-20-2017 08:18 PM
So I only need to use the 4 bolts that bolt through the axle housing?
darkminion_17 11-20-2017 08:22 PM
3 bolts, two for the rear end axle housing, and one up front where the hanger would be.
J-Mech 11-20-2017 08:55 PM
3 bolts per side....6 total. :beerchug:
Oak 11-20-2017 09:19 PM
Did you change the guts too or are you keeping the GT gears and such in it?
