bbrown8 |
12-05-2017 04:52 PM |
Losing Hardware
So I'll start off by saying I still love my Cub. This summer has been hard on me and the Cub. I feel like she is just falling apart. I like to take care of my equipment and have done what I feel is the right maintenance. Greasing all zerks, changing oil, running pure gas with a little Marvel in it, overhauling the carb, new air filter, new Hyrdro fluid, and more. I mow/operate at a pretty low speed when working in/on the yard. I know running her fast over rough terrain is going to strain things. I have a lot of roots towards the edges of my yard. I have to traverse those at a snails pace. Again, I understand if you push equipment beyond its limits it will fail. I don't feel that I am doing that.
My main complaint is the tractor seems to be shedding all kinds of nuts and bolts left and right. I contribute this to vibrations. The engine is running fine and has all its power. I replaced the ISO motor mounts this spring with OEM new ones - all 8 of them. I thought that helped get rid of some vibrations, but I still seem to be suffering from a machine wanting to shake itself to pieces. I have not replaced the flex disc couplings. I have inspected the hardware on them and they seem to be fine, but since they are assumed to be original replacing them should help. Should I go to solid motor mounts too?
She has rattled loose the muffler twice resulting in fatigue cracking a repair done by the prior owner to a point of no return. So I replaced a muffler - those are spendy. Now my aluminum muffler shroud is all cracked up and the muffler elbow keeps coming loose. I am going to make a muffler prop to help. Replacing the aluminum shroud is a lot of money, so I am going to try TIG welding them back together at work when I get a chance. All of the tin shrouding nuts/bolts seem to want to rattle off even with lock washers and blue loctite. The loctite may not be setting fully before I operate it - so I will take some blame there.
I can't seem to keep the hood in proper adjustment and put in new hinge pins after one broke in half. I replaced them as a set. I added some automotive weather stripping around the instrument cluster where the end of the hood rests to take out some vibration/rattle. That was a great help and looks factory. The hood came loose Saturday and I was back to looking like Jed Clampett while I aerated my lawn for the final time of the year.
So, what have you guys experienced here? Anyone losing their minds over losing hardware? :bash:
