-   -   1772 Side panel spring pics (https://www.onlycubcadets.net/forum/showthread.php?t=50842)
MWShaw 12-14-2017 07:41 AM
3 Attachment(s)
FrankF3 had sent me a PM about the spring placement on my 1772.
I saw no way to share pics in a PM, short of a web address.
Photobucket has changed thier photo sharing guidelines, so I decided to post them here.
darkminion_17 12-14-2017 10:13 AM
Emails work best between others to share pics.
You will get the full resolution of the picture file.
P.S. you should move your hose clamp closer to the radiator.
jbrewer 12-14-2017 01:37 PM
Looks pretty much the same arrangement as the 782D
finsruskw 12-14-2017 06:13 PM
And Cub Cadet 882
darkminion_17 12-14-2017 06:15 PM
And a Cub Cadet 1512.
Some brass or rubber inserts in those holes will keep them from wearing thru.
zippy1 12-14-2017 10:50 PM
And 1872. Oh, and my 782.:biggrin2:
FrankF3 12-23-2017 05:00 PM
4 Attachment(s)
Well, I finally got around to taking some pictures of my 1772 to compare what the springs look like on Mike's machine. There is SOMETHING DEFINITELY different! The side panel springs do not make a straight run from side to side as they connect to the side panels. They just about make a 45 degree bend as the hooks connect to the side panels on BOTH sides.
Any ideas??
Attachment 89716
Attachment 89717
Attachment 89718
Attachment 89719
MERRY CHRISTMAS and a Happy NEW YEAR TO ALL!!!
darkminion_17 12-23-2017 06:57 PM
Seems like you have some side panel/ front grill housing alignment issue that needs attention.
Is that an OEM spring as it looks chubby.
FrankF3 12-23-2017 08:04 PM
Yes that is an OEM spring - about the 4th or 5th one. When the spring is not on, the panels rest as they should. When you put the spring on, it pulls up on the front of the side panels causing the gap you pointed out. Now the big question is what needs to move to get the alignment correct? :bigthink:
DieselDoctor 12-23-2017 09:46 PM
In the pictures at the beginning of this post, that tractor does not have the removable debris screen in place in front of the radiator, and the spring is setting down where the "handle" of the screen would normally be. On the pictures of your tractor, the spring is sitting on top of the screen handle.
I think!
