Cub Cadet 149 Wont Start
My 149 wont start, the starter solenoid was just clicking away and was not turning the starter/generator. I went ahead and changed the solenoid and now its doing the same thing and still wont start. I put a meter on the starter and its only intermittingly getting voltage when I turn the key. After a few trys it wont do anything now. Also, the head lights will not work now also. The battery is showing 12.5 volts. Any ideas?
If not, you could have a bad ground cable, or a bad battery or a bad starter/generator. |
Well I reckon it's time to clean up all ground connections and all the connections in the start circuit.:bigthink:
Performing a voltage drop test may also be helpful in isolating a faulty wire or connection; https://www.youtube.com/watch?v=paw8...t=37s&index=22 Good luck!:beerchug: |
Pull both Battery Cables, on both ends. Clean & polish the cable ends. Make sure the newly cleaned ends come in contact with clean terminals and bare metal.
:IH Trusted Hand: |
http://www.onlycubcadets.net/forum/s...ad.php?t=34457 Factory connectors and every single connector is marked so even someone like myself who isn't that good with electrics can hook it up easily. As an added bonus, they are a very good value too. |
| All times are GMT -4. The time now is 01:25 AM. |
