-   -   Head bolt question (https://www.onlycubcadets.net/forum/showthread.php?t=51339)
Oak 02-21-2018 08:51 PM
Head bolt question
I have a leaking head gasket on an Onan P216 so I pulled both heads the other night and of course one bolt broke off about 1/4 above the block.:angry:
I looked just about everywhere and can't find replacement bolts....OEM are too much $.
The bolts are 5/16 X 2" long with 1.5" of them threaded. Where is a good place to find them? I've looked at McMaster, Summit, GreedBay, Amazon & Googled them but I can not find a grade 8 bolt to match. TIA:beerchug:
DeltaCub 02-21-2018 08:55 PM
Fastenal? :bigthink:
Jeff in Pa 02-21-2018 09:05 PM
https://www.ebay.com/sch/i.html?_nkw...dmd=1&_ipg=200
DeltaCub 02-21-2018 09:08 PM
https://www.nutsandbolts.com/hex-hea...25-p-1391.html
Oak 02-21-2018 10:28 PM
Thanks all. I looked at a lot of those this morning but they didn't give the thread portion like McMaster does. Most of the grade 8's don't match the amount of threads on the OEM.
Look at the cad drawing of the partially threaded 5/16x2".
https://www.mcmaster.com/#91257a591/=1boaa2x
I don't think that will work. Would there be any issue using a fully threaded bolt? I'm thinking no but I sure wish the partially threaded would match better.
J-Mech 02-22-2018 12:15 AM
Todd, don't you have a local hardware store or something that sells bolts? My local stores do, and so does Rural King. (I know RK's aren't in the south, but TSC, ect...)
There is no issue using an all threaded bolt. How long of threads do you need to go into the block? Should be a flat washer on there too, isn't there?
Oak 02-23-2018 08:26 AM
I'm an idiot!:BlahBlah:
I didn't think these China bolts would work from TSC by looking at them.
Attachment 91009
It looks like they will work if I use the original washer and add 1 more.....guess I shoulda checked before I posted.:Spank:
Sam Mac 02-23-2018 09:14 AM
How about studs?:bigthink:
You could also try ARP, they make some great stuff for race engines :beerchug:
http://arp-bolts.com/
This is a 5/16X 2 bolt
http://arp-bolts.com/kits/ARPkit-det...?RecordID=2689
darkminion_17 02-23-2018 09:22 AM
Looks like you need more thready thingys, any 5/16 dies?
Sam Mac 02-23-2018 10:31 AM
Another option. :beerchug:
