Solenoid swap?
Got a bad solenoid on my cub 125, its the 3 post version, i have a 4 post that i pulled from a cub laying around, can i make it work on the 125, or do i need to buy a new three post? Thanks
metalrain |
YUP....it will work.
The differences between the 3 and the 4 terminals solenoids are, the 3 terminal solenoid uses case ground for the negative (black wire) side while the 4 terminal solenoid as the extra terminal not tied to the case. |
Perfect....i'll give it a try...Thanks
metalrain |
Changed out the solenoid, works perfect. Thanks for the help Roland.
metalrain |
| All times are GMT -4. The time now is 12:34 PM. |
