GT 2550 steering bushings
I have a 2009 GT 2550 with 70 hours. While changing oil I noticed some play in the steering. After inspecting I found that the bushings one the end of the drag link that bolts to the steering gear assy where worn. 941-0475 Just plastic bushings. Are there any brass replacements or do I just replace every 70 hours.
Possibly Jeff in Pa. could make them for you, if Granger has nothing that would work.:bigthink: |
Measure the ID and OD and order some bronze bushings from McMaster (click on Flanged Sleeve Bearings)
https://www.mcmaster.com/#bronze-bushings/=1dsnu1j |
I will do. That place has everything. I got some tie rod ends that were HIGH quality and way less than cub cadet. Thanks for the reply.
Several years ago now I was searching for a replacement bushing for my steering and ordered these. I don’t really remember now why I didn’t go with bronze but these have held up for me better than the OEM ones.
https://www.mcmaster.com/#2706t17/=13vdfu9 |
Another quick and cheap fix from these guys. Thanks for the help
| All times are GMT -4. The time now is 07:33 AM. |
