Side panel screws
Made some screws for my 1250 side panels. Thumb screws, couplers, T-nuts and red Loctite. Makes it easier to get to the fuel shut-off valve.
https://i.imgur.com/G5EXpb8.jpg?1 https://i.imgur.com/pPoIJdc.jpg?1 https://i.imgur.com/lPhugo0.jpg?1 |
Why would you need to get to the fuel shut of valve that often?
Most hardware stores carry wing nuts and bolts.... |
I like it! Anything that makes life a little easier is a good thing!
:beerchug: |
Cool, the panels seem to have to come off as quickly as I install then back on. Especially while I continue to iron out kinks. This would make the removal that much faster.
Yes they do. That's where I got these. I wanted something one piece, the right length, and something so I didn't have to deal with washers. This is what I came up with. |
Do you shut the gas off on your truck when you put it in the garage? |
I always shut the fuel off on the 784 but i added a shut off right before the fuel pump so all i have to do is lift the hood. I once had a Cub that developed a pin hole in the float and it emptied a full tank of fuel on my shed floor, sure wish i would have shut the fuel off on that tractor, took forever for the smell to go away.
My truck? It's not gravity fed. |
Nice setup there Mr wnkl.:beerchug:
I shut my fuel off too.:ThumbsUp: But what do I know. I clean my spark plugs too. |
| All times are GMT -4. The time now is 05:11 AM. |
