High temp. paint question?
My wife was looking at my muffler. Well not my muffler but my # 109's muffler. She thought it looks 'ICKY'. It does but solid as can be.
Question to anyone? Will High Temp black, paint work on it to spiff it up a bit? The one that they use for engine's? Or how about the paint for BarBq's? Or will I be starting other issue's? Thanks, Nik |
I've had good luck with bbq grille paint in the past on mufflers. It may need re-coating once in a great while, but it holds up pretty well for a working tractor.
I have also used VHT paint on several exhaust systems as well. Most recently on a 72' Honda CB750 4 into 1 Yoshi header and so far it has held up great. Thankfully this place (link below) is 20 minutes from my house, as I don't think you can just stop down to the auto parts store and pick this stuff up. I also used the engine enamel on a few CB's that I have restored over the years, and it holds up very well. http://www.caswellplating.com/vht/vht_high.htm Jeff (teet) |
Got it off.
Solid as can be, seems to have been re-placed maybe 5/8 yrs. ago? Brush off the rust & paint? <OR>? http://i210.photobucket.com/albums/b...tractor026.jpg |
Jeff (teet) |
That muffler is probably 25 years old at least and might be original. Newer ones are painted black, I think.
Matt- I just painted mine yesterday with 1200 degree grill paint (Rustoleum). I used a wire wheel on the grinder to clean it up. It painted up beautifully, but I can't testify to how long it will last. I really liked the paint.
My local advance auto parts carries the VHT Ceramic paint. This stuff is great.
I did 2 mufflers last year with it and they still look great. I just wire brushed the mufflers good and put a couple of coats on them and then followed the directions on the can about warming up and cooling down a few times. |
| All times are GMT -4. The time now is 08:43 AM. |
